R7800 Voxel Firmware NFS share support
2 posts / 0 new
Gfontana13
Hi! I need to replace my old Belkin router because it died a few weeks ago. I Was using an old open source firmware with embedded NFS share that worked very well. I chose nfs to setup a movie fileshare for Kodi because in my experience is faster and more reliable than SMB. Non my question is: does R7800 with voxel firmware support nfs share? Is it easy to setup? What about performance? Thanx!
P.s. Sorry for the three empty topics. I’m posting from my smartphone and something went Sting the first time. I didn’t find the option to Remove them...
Voxel
NFS should work if you setup
NFS should work if you setup Entware. It requires some experience in Linux management.
But FYI: SMB is fast enoug in my build Check this:
https://www.snbforums.com/threads/r7800-write-speed-usb.33495/#post-444030
