Support for IPaddr to URLs/ports restrictions in ACLs for R7800?
2 posts / 0 new
eeeehaw
eeeehaw's picture
I have  a two new R7800 devices here: one is set up as a WAP only, the second has WiFi radios off and is my gateway/edge router to the ISP; they are 50ft apart in the house connected together with Cat6e.  I am looking for a solution where I can restrict certain WiFi connected devices from accessing specific URLs, and using specific ports & protocols, similar to how router inbound/outbound ACLs in enterprise routers can be configured.  Of course, the stock Netgear firmware does not provide for this.
Does DD-WRT, or other compatible open firmware, provide this functinality?
e38BimmerFN
e38BimmerFN's picture
I would post about this here
I would post about this here as well:
https://forum.dd-wrt.com/phpBB2/viewforum.php?f=1&sid=b5ea48623f883061fb...
You my try Voxels FW, however i don't know if his does much more. There is add-on packages that may. You can find his info here:
https://www.snbforums.com/forums/netgear-ac-wireless.53/
