extermly slow wifi speed with dd-wrt
5 posts / 0 new
buyer
buyer's picture
on R9000 router post installing kong ddwrt version the wifi connection speed fall to around 200mbps and with netgear stock i get around 90pmbps.
comparison is witj all the setting been identical.
has anybody faced similar issue ? any fix ?
buyer
buyer's picture
Correction : 900mbps
jfosella
jfosella's picture
You need to change the
You need to change the channel width on 5 ghz tto make it the same. Set it for 80mhz
buyer
buyer's picture
it is already set to 80mhz ,
it is already set to 80mhz , the setting are identical for netgear and dd-wrt.
i have tried all the possible combinations.
any things else that could be missing ? anybody else on x10 having similar issue?
henrydevid
henrydevid's picture
This is a very common matter
This is a very common matter for the user, I suggest you go Cisco Support to sort out this issue.
