Adding proxy and radius to WNR3500Lv2
2 posts / 0 new
ngcutura
Hello everybody,
I just bought WNR3500Lv2 that I want to insert into my existing network. I have a couple of questions about it:
1) Can I use out-of-the-box router and access it via terminal (ssh, telnet) to set the rules via iptables? If not, which other firmware available I need to use?
2) Does out-of-the-box router support adding a proxy and a radius server? (Manual configuration in Linux is known to me.)
Thanks and best regards,
NGČ
peter gomez
You can use out of the box
You can use out of the box router and access it via terminal to the rules. And don't think you need to use any firmware. I don't have an answer for your second question. I would recommend posting in facebook groups as well. People are more active there.
