- After the initial Kong Mod 1 year 1 month ago
- Working the EXACT same 1 year 1 month ago
Is it the Kong build, if so you need to use the .bin file which can be found here..
http://www.desipro.de/ddwrt/K4-AC-ALPINE/
ddwrt-netgear-R9000.bin
Hi Guys, I have the same problem.. I would remove Firmware: DD-WRT v3.0-r33010M (08/09/17) from my R9000.. I don't know how to restore netgear original firmware.. could you kindly help me?
Dear all,
I also wish to know how to restore back to Netgear's firmware from Kong's firmware. Do I just use the file and in the router (Kong's firmware) do I there do the firmware upgrade with ddwrt-netgear-R9000 or do I do by the link provided by Netgear to restore and then select the ddwrt-netgear-R9000?
For your info. I did try both. But the KOng's firmware is keep getting back. Do I need to do something else? Like after using ddrwt-netgear-R9000 installing an official firmware from Netgear or do a hard resset or ...???
Are you installing ddwrt-netgear, or ddwrt-to-netgear, because they are not the same thing. You need to install the latter.
http://www.desipro.de/ddwrt/K4-AC-ALPINE/NetgearFW/
I installed DD-WRT Kong Mod for NETGEAR R9000 (2017-10-16 img), Wrong Firmware !!!
dd-wrt-netgear-R9000_BIN_20171016.zip does not work
I can not restore the original R9000 firmware.
ask for help!
Thanks!!
I had tried restoring firmware as well on my R8500 by upgrading the firmware to the stock netgear firmware but it keep defaulting back to dd-wrt. Is there something I am doing wrong?
Hello
It was finally done to me
I'll rethink an older 217.05. ddwrt firmware-
ftp download 2017 .02 dd-wrt to Netgear 9000 ..
ddwrt initial position
by admin
password default !!!!!!!!!
https://www.youtube.com/watch?v=s6IoJJQcLmY
Only with a chrome browser !!!!!!!!!
