- After the initial Kong Mod 1 year 5 days ago
- Working the EXACT same 1 year 5 days ago
- While the "5 Easy Steps" 1 year 2 weeks ago
- R8000P would be grate to see. 1 year 2 weeks ago
- Have a R8000 but ordered a 1 year 2 weeks ago
I have just purchased a D7800 for use as a BTHUB replacement. One problem with the Hub6 is that it insists on adding -5 to the 5GHz network SSIDs, and well, I want them named as I want them named!
So I installed D7800-OpenWRT-Dec012015 - had trouble with normal installation methods but tftp seemed to work. One VITAL p[iece of information omitted in the notes is that if you want the modem to work, you need to add under WAN phisical settings a custom interface with the parameter ptm0.101 in it. The modem will not work otherwise! Othersettings are as in the readme file under VDSL PTM DHCP
But I am still having problems withj the stability of the wifi. I was warned that using save and apply on wifi would crash the router.. well this seemed to get worse and now the router crashes always a few minutes after boot, seems to be as the wifi is coming up. Boot is slow, at least 2 or 3 minutes!
Anyone else using this firmware with Btinfinity got any tips?
I recently purchased a D7800 and also want to install VPN at the router. I will be using the modem as well. Have there been any updates to the firmware in support of this?
