I just bought a RAX80, which I think I'm going to return because although it says you can hook up a lot of devices, it doesn't say that it stops assigning IPs at #65. I have about 200 iot, simultanious connected devices that I'm sending small bits of information every minute or so. Are there any routers/custom firmware configurations that you can recommend that could handle communicating with that amount of devices?
*sidenote, I was using a linux build with usb wifi on an old laptop that had no problem with communicating with that many devices. So if that little thing can handle it, there has to be a router that can too. Unfortunately I'm unable to continue using that custom linux build.
Joe
