The doc is wrong speed must be set to 115kb not 38.4.
Now that I can talk to it, how do I get control of the wgr614 to try and reload the firmware???
looking at the output from the monitor it appear that there is no way to use it.
attach boot up output from wgr614::
CFE for WGR614v8 version: 1.3 Build Date: Fri Apr 20 14:04:44 CST 2007 et0: Broadcom BCM47xx 10/100 Mbps Ethernet Controller 4.138.1.0 Device eth0: hwaddr 00-1E-2A-54-22-86, ipaddr 192.168.1.1, mask 255.255.255.0 gateway not set, nameserver not set Loading ............................ CPU revision is: 00029029 Primary instruction cache 16kb, linesize 16 bytes (4 ways) Primary data cache 16kb, linesize 16 bytes (2 ways) Linux version 2.4.20 ([email protected]) (gcc version 3.2.3 with Broadcom modifica tions) #197 Fri Feb 29 02:11:48 EST 2008 Setting the PFC to its default value Determined physical RAM map: memory: 01000000 @ 00000000 (usable) On node 0 totalpages: 4096 zone(0): 4096 pages. zone(1): 0 pages. zone(2): 0 pages. Kernel command line: root=/dev/mtdblock2 noinitrd console=ttyS0,115200 CPU: BCM5354 rev 1 at 240 MHz Calibrating delay loop... 237.56 BogoMIPS Memory: 14600k/16384k available (1233k kernel code, 1784k reserved, 100k data, 6 8k init, 0k highmem) Dentry cache hash table entries: 2048 (order: 2, 16384 bytes) Inode cache hash table entries: 1024 (order: 1, 8192 bytes) Mount-cache hash table entries: 512 (order: 0, 4096 bytes) Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes) Page-cache hash table entries: 4096 (order: 2, 16384 bytes) Checking for 'wait' instruction... unava POSIX conformance testing by UNIFIX PCI: no core PCI: Fixing up bus 0 Linux NET4.0 for Linux 2.4 Based upon Swansea University Computer Society NET3.039 Initializing RT netlink socket Starting kswapd devfs: v1.12c (20020818) Richard Gooch ([email protected]) devfs: boot_options: 0x1 Squashfs 2.2-r2 (released 2005/09/08) (C) 2002-2005 Phillip Lougher Serial driver version 5.05c (2001-07-08) with MANY_PORTS SHARE_IRQ SERIAL_PCI en abled ttyS00 at 0xb8000300 (irq = 3) is a 16550A ttyS01 at 0xb8000400 (irq = 0) is PPP generic driver version 2.4.2 pflash: found no supported devices sflash: squashfs filesystem found at block 580 Creating 8 MTD partitions on "sflash": 0x00000000-0x00020000 : "boot" 0x00020000-0x003b0000 : "linux" 0x000912cc-0x003b0000 : "rootfs" 0x003b0000-0x003c0000 : "T_Meter1" 0x003c0000-0x003d0000 : "T_Meter2" 0x003d0000-0x003e0000 : "POT" 0x003e0000-0x003f0000 : "board_data" 0x003f0000-0x00400000 : "nvram" NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP IP: routing cache hash table of 512 b TCP: Hash tables configured (established 1024 bind 2048) NET4: Unix domain sockets 1.0/SMP for Linux NET4.0. NET4: Ethernet Bridge 008 for NET4.0 802.1Q VLAN Support v1.7 Ben Greear <[email protected]> All bugs added by David S. Miller <[email protected]> VFS: Mounted root (squashfs filesystem) readonly. Mounted devfs on /dev Freeing unused kernel memory: 68k freed Algorithmics/MIPS FPU Emulator v1.5 Reading board data... WSC UUID: 0x6b4ff8cdd6688c1a39c35c8bb98ff6c6 pa0maxpwr - 82 pa0b0 - 0x164B pa0b1 - 0xFA6 pa0b2 - 0xFE86 opo - 8 configure RF parameters OK Using /lib/modules/2.4.20/kernel/drivers/net/et/et.o insmod: bcm57xx.o: no module by that name found Using /lib/modules/2.4.20/kernel/drivers/net/wl/wl.o Hit enter to continue...WARNING: console log level set to 1 ********************************************* Wi-Fi Simple Config Application - Intel Corp. Version: Build 1.0.5, November 19 2006 ********************************************* Initializing stack...button monitor start...! OK Now starting stack get mac = 00 1E 2A 54 22 86 DEVICE PIN: 91050403 eth1: ignore i/f due to error(s) Reading board data... WSC UUID: 0x6b4ff8cdd6688c1a39c35c8bb98ff6c6 Using /lib/modules/2.4.20/kernel/net/ipv4/acos_nat/acos_nat.o insmod: unresolved symbol acosNat_IpFragInput insmod: unresolved symbol acosNat_IpFragOutput insmod: unresolved symbol acosNat_unregister_hook insmod: unresolved symbol acosNat_register_hook open failed:: No such file or directory dnsRedirectReply.c: Can't open device file: /dev/acos_nat_cli info, udhcp server (v0.9.8) started error, unable to parse 'option wins ' error, unable to parse 'option domain ' Can't open device file: /dev/acos_nat_cli Can't open device file: /dev/acos_nat_cli Can't open device file: /dev/acos_nat_cli Can't open device file: /dev/acos_nat_cli Can't open device file: /dev/acos_nat_cli Can't open device file: /dev/acos_nat_cli Can't open device file: /dev/acos_nat_cli Can't open device file: /dev/acos_nat_cli Can't open device file: /dev/acos_nat_cli Can't open device file: /d Can't open device file: /dev/acos_nat_cli Can't open device file: /dev/acos_nat_cli Can't open device file: /dev/acos_nat_cli Can't open device file: /dev/acos_nat_cli Can't open device file: /dev/acos_nat_cli Can't open device file: /dev/acos_nat_cli Can't open device file: /dev/acos_nat_cli Can't open device file: /dev/acos_nat_cli POT integrity check OK. Can't open device file: /dev/aglog wl: Unsupported Start DHCP client daemon info, udhcp client (v0.9.8) started Hit enter to continue...eth0: No such process
DEVICE PIN:91050403 WSC: In unconfiged AP mode, wait for start command.... tlvPtrChar* : func CMasterControl_InitiateRegistration line 656 allocating memo ry 0x10003680 for 0x10003668 Waiting for Registrar to connect...
BusyBox v0.60.0 (2008.02.29-07:05+0000) Built-in shell (msh) Enter 'help' for a list of built-in commands.
# help
Built-in commands: ------------------- . : break cd continue eval exec exit export help login newgrp read readonly set shift times trap umask wait
By the way I have noticed in your earlier email about this BPS 38.4 Kbps. Which doc are you using. The one that you should use is this one and it does have the correct baud rate. We would need to get the documentation corrected and we appreciate your effort on this a lot. I will respond to other threads separately.
It is evident from the dump that every time your kernel is trying to boot. Actually you need to press ctrl+c while rebooting the router to get the CFE prompt. Please try that.. if you have already done so please make sure that your minicom is properly configured.
We've just published an article by BrandonC showing how to recover the WGR614L router using a serial console and cable. I thought this may be of interest to those participating in this thread!
I finally got access to the wgr614.
zone(1): 0 pages.
zone(2): 0 pages.
PCI: no core
Starting kswapd
abled
pa0maxpwr - 82
pa0b0 - 0x164B
pa0b1 - 0xFA6
pa0b2 - 0xFE86
opo - 8
OK
Now starting stack
wl: Unsupported
DEVICE PIN:91050403
# help
Built-in commands:
Thank you
Howard R. Levy
I finally get into the console
what command should be used to reload the firmware from the debug console??
tftpd.
Please check my recent blog at
http://www.myopenrouter.com/blog/entry/10224/Firmware-upgrade-using-console-and-boot-loader/
Nachi
Nachi
Nachi,
On one of my routers that won't boot I see an ifniite loop in the serial console. It just starts over and over again.
So I never get to the CFE prompt. Any ideas on this?
Thanks for the tip. Got it now. Up and runnng.
You can find the article here:
Recover Your WGR614L Using A Serial Console & Windows
