Firmware upgrade failed. Please check your file.
12 posts / 0 new
seaner
Hi all,
Just picked up a brand new WGR614L, opened the box, set it up minimally, and am just trying to update the firmware to no avail.
I've tried both the v1.1.2_1.0.23 firmware and the v1.11.041510 tomato firmware and simply get the following message after hitting the 'upload' button on the Router Upgrade page:
"Firmware upgrade failed.  Please check your file."
It's a WGR615V9 running V1.0.9_1.0.1NA.
Haven't got around to wiring up the console yet.  Any suggestions?  Known issues?
Cheers,
Sean
rakha
Have you tried the chk file?
Have you tried the chk file? For the Tomato release you should try the chk file - 'tomato_wgr614l.chk' not the trx one,
seaner
Yup. Tried the .chk files
Yup. Tried the .chk files from both tomato and netgear firmware downloads. no love :(
SouvikGhosh
I have tried to upgrade
I have tried to upgrade firmware from the Tomato release. I am not sure whether the default Netgear firmware has any issue in it. Actually in may case, I have tried with serial console and as usual it went fine for me....:) I will definite check your issue. Please keep it touch..
seaner
Just to clarify, I am trying
Just to clarify, I am trying to upgrade FROM the default firmware, TO the tomato firmware.
Not quite sure why I paid the extra money for a box that can't seem to accept upgrades.
seaner
a bit of progress here... I
a bit of progress here... I was able to upgrade to WGR614v9-V1.1.0.15.chk from the netgear site.
Is there a bit of a model numbering mismatch between the 614v9 and 614L firmware files perhaps?
SouvikGhosh
yes, I guess that was the
yes, I guess that was the reason. The image you tried is for 614L. And for your information, you will not be able to run the opensource firmware in 614v9 since it has 2 mb flash.
rakha
check the link to bring up
JTKWales1981
I have the same problem with
I have the same problem with my router but i think my firmware has been locked by my ISP to theirs and i need a way of upgrading it to netgears own to solve the problems im getting!
twindragon6
SouvikGhosh said:
The latest version of the Netgear firmware does have an issue with the DD-WRT firmware image and other Netgear firmware. I think they changed something someware in how the image is verified. I don't know about others. To flash the DD-WRT firmware onto it I had to roll back the firmware to a previous version; useing the tftp method and reverting to an older version of the fimware. Then rebooting before proceeding to upgrade to the DD-WRT...
Sprucegoose
I got Netgear WGR614 v9 ... i
I got Netgear WGR614 v9 ... i there any custom firmware i can install on it..
want to know if there is any upgrade that can boost my signal strength other than a hardware solution.
Kimoy
Can someone help me? Im
Can someone help me? Im trying to upgrade my firmware dgn2200 netgear. But it always say " upgrade failed, please check your file". Why is this?
