DD-WRT has been available for a week or so now. How many folks have tried it? I put it on and it seems to work great.
I was unable to use my wrt614l after the upgrade with dd-wrt. Because the power led was blinking i used a tftp program to put a tomato firmware on.
It's a special version called izma version 1.11.41512. It's ok but i would like to put dd-wrt like in my linksys wrt54.
Does someone use a european version of wrt614L because it seems to be the problem
if you try to use the netgear gui or even a tftp program to upgrade?.
Thanks a lot
