I have a Netgear WGR614 v8 and I was able to load Tomato 1.11.0018 on it.
All in all, it works but has some quirks. As such I've tried upgrading to the latest available verision without success. For starters, the web upgrade starts with this complaint when I try to upload "tomato-wgr614l-1.11.41512-lzma.chk":
Expecting a ".bin" or ".trx" file
If I rename the file to .bin prior to upload, it accepts it but fails with:
File contains an invalid header
Please wait while the router reboots...
The same happens for the latest Netgear firmware "wgr614v8_1_1_11_6_0_36_na.chk".
What am I doing wrong? How do I upgrade Tomato or revert to the Netgear firmware?
I do have ssh enabled to the current Tomato, but when I try to debug update.cgi which is called by the web update, its nowhere to be found on the filesytem...
Thanks Axelabs, for posting this issue. This issue was solved in the 1.11.041510 version of Tomato. But probably the Europian version does not contain this fix. I will check this issue and will let you know...
Axe labs I am about to post an utility to erase your existing kernel. If you run this utility susing ssh and reboot the router, the router will be in TFTP listen state and you then can load any of your desired firmware using tftp without having serial console. Please stay tuned - I will let you know...
Axelabs I have created an article to solve your problem... Please refer to the link below http://www.myopenrouter.com/article/10496/How-To-Switch-Firmwares-on-the...
Souvik, the tool worked like a charm! I'm running the latest version of Tomato now.
Much thanks!
-axelabs
Did you install the latest version of Tomato available on polarcloud or is it a modified version. Any issues with it?
I've upgraded to version 1.11.41511...
That firmware is linked off the home page of myopenrotuer.com...
So far everything is running smooth :)
C'mon guys.. is Wireless Connectivity working with this Firmware?
I have uploaded tomato to my WGR614l board. Image is downloaded from http://www.myopenrouter.com/download/10413/tomato_wgr614l-lzma/
I can see only few pages. I am not able to go to Tools, Advanced, Administration pages. Is there anybody who faces the same problem?
I have compiled the source code taken from http://www.myopenrouter.com/download/10286/Tomato-for-WGR614L-v1.11.0415...
Now all pages are coming. I am not able to understand what was the problem with the previous firmware.
Wireless connectivity is working fine with the security disabled and with WEP.
