HI all,
when im booting my Jffs2 filesystem image on my target board of AT91SAM9261 atmel board with the linux kernel image ..im getting these message which is causing my jffs2 to load slowly..
JFFS2 notice: (721) check_node_data: wrong data CRC in data node at 0x056fe800: read 0xa35d5792, calculated 0xd7b5d1a5.
JFFS2 notice: (721) check_node_data: wrong data CRC in data node at 0x06260800: read 0xa5369999, calculated 0x6deda12a.
yeah this is ARM processor. The loading of the filesystem is taking a lot of time.
im using a linux kernel , and a jffs2 file system for my Nand flash memory . If u want any more inputs let me kmow . does anybody has faced a similar problem?
warm regards,
Ravi Kulkarni
