Hi Guys,
Updated my ASUS WL-520GCwith DD-wrt mini. No issues with the firmware upgrade. Set up the router as client bridge. Once again no issues. The asus router sees my other netgear router mac address and shows the signal strength as 100%. Yet I'm unable to still connect. Any help is most welcome
In DD-WRT gui , you will see a heading "status" . Once you click it you will all available networks you can connect your bridge to . Click the corespondig connect button and you will be able to associate with desired primary router .
