HWaddr FF-FF-FF-FF-FF-FF / 00:FF:FF:FF:FF:FF
4 posts / 0 new
mikie
CFE for WGR614v8 version: 1.3
Build Date: Wed Apr  4 11:00:42 CST 2007
Device eth0: hwaddr FF-FF-FF-FF-FF-FF, ipaddr 192.168.1.1, mask 255.255.255.0
ifconfig command (OpenWRT in router) returns:
br-lan    Link encap:Ethernet  HWaddr 00:FF:FF:FF:FF:FF
          inet addr:192.168.1.1  Bcast:192.168.1.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:5436 errors:0 dropped:0 overruns:0 frame:0
          TX packets:4163 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:570686 (557.3 KiB)  TX bytes:1486848 (1.4 MiB)
eth0      Link encap:Ethernet  HWaddr 00:FF:FF:FF:FF:FF
          RX packets:10225 errors:0 dropped:0 overruns:0 frame:0
          TX packets:9186 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:2221196 (2.1 MiB)  TX bytes:2176144 (2.0 MiB)
          Interrupt:4
eth0.0    Link encap:Ethernet  HWaddr 00:FF:FF:FF:FF:FF
          RX bytes:592430 (578.5 KiB)  TX bytes:1503500 (1.4 MiB)
eth0.1    Link encap:Ethernet  HWaddr 00:FF:FF:FF:FF:FF
          inet addr:10.129.9.8  Bcast:10.129.9.255  Mask:255.255.255.0
          RX packets:4790 errors:0 dropped:0 overruns:0 frame:0
          TX packets:5024 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:1444812 (1.3 MiB)  TX bytes:635554 (620.6 KiB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
wl0       Link encap:Ethernet  HWaddr 00:FF:FF:FF:FF:FF
          BROADCAST MULTICAST  MTU:1500  Metric:1
          Interrupt:2 Base address:0x5000
as you can see  00:FF:FF:FF:FF:FF everywhere
could you help me, how can I replace  00:FF:FF:FF:FF:FF  to something from bottom cover of router?
with thanks
mikie
mona
you can set a temporary MAC
you can set a temporary MAC in CFE like
CFE> ifconfig eth0 -hwaddr=00:01:02:03:05:05 -addr=192.168.1.1
then download the netgear default firmware to execute the burnethermac command like
burnethermac 001122334455
burnboardid U12H072T00_NETGEAR
I think this will solve your problem.
mikie
so I have to understand my OpenWRT firmware with netgear default firmware, next reboot router..
Do I have to let it boot, or stop it with Ctrl+C in CFE>? I think CFE doesn't have commands like "burnetherac" or "burnboardid"
thanks
mikie
mona
First go to the CFE prompt
First go to the CFE prompt using Ctrl+C. Then give the command
Now you are able to run tftpd. So you can upload new image. Please upload Netgear's default firmware. It has burnethermac command. So give those two commands. Then reboot it again. It will get proper hw address. Now you can upload any firmware.
