It really great to see another new version of the Tomato firmware. It wonderful that to see that Netgear is continuing Developing/updating the great Tomato firmware for the 614L board.... I have already downloaded the code and started testing it. The firmware upgrade issue has been solved and the wireless is enabled by default..... Great.. thanks to the team.. I will continue testing this firmware and will update my findings soon...
cheers.....
Is it... Great I was waiting for it... From where can I download the firmware?
check ou the download section. it is there ...
http://www.myopenrouter.com/download/10286/Tomato-for-WGR614L-v1.11.0415...
can any body let me know how to compile the source?
Follow the steps as mentioned in the blog by tathagata das. The resultant image for the Netgear board will be placed in image/tomato_wgr614l.chk.
I am trying to compile the new tomato firmware for wgr614l as mentioned in the blog. But I am getting the error
/bin/sh: line 1: 15542 Floating point exceptionscripts/bb_mkdep -I /home/mona/Tomato/17.04.tomato/bcm5354/src/router/busybox/include /home/mona/Tomato/17.04.tomato/bcm5354/src/router/busybox >.depend.tmp
make[3]: *** [.depend] Error 136
make[2]: *** [_all] Error 2
Could anybody help me to solve this problem?
My last post is not showing completely . So I am posting again.
____________________________________________________________________________
>.depend.tmp
make[2]: *** [_all] Error 2 _____________________________________________________________________________
I have tried it out in my machine. It compiles fine here. I have FC6....
my os is Red Hat Enterprise Linux 2.6.9-34.ELsmp
remove "bb_mkdep" from bcm5354\src\router\busybox\scripts and re-build
The problem was related to the dependencies. It is already solved.
Tahtagata and Mona
Thanks for your prompt reply! Mona, can you please let me know how dependency issue was resolved? I was able to get past the "Floating point exceptions" error in bcm5354\src\router\busybox\scripts by my above change. However, past that almost toward end I get the following:
bcm5354/src/mksquashfs/mksquashfs-lzma /home/deng/Tomoto_Route/bcm5354/src/router/mipsel-uclibc/target /home/deng/Tomoto_Route/bcm5354/src/router/mipsel-uclibc/target.image
make[1]: *** [install] Floating point exception
make[1]: Leaving directory `/home/deng/Tomoto_Route/bcm5354/src/router
I am trying this on a Fedora machine with following kernel.
Linux xl-sj1-18 2.6.9-67.ELsmp #1 SMP Wed Nov 7 13:56:44 EST 2007 x86_64 x86_64
x86_64 GNU/Linux
Need to know (1) What is the correct source code I should be working with (2) Tested and known build environment to build this.
Also, one quick question on the side - can one of you please tell me if I just need Qos and nothing else beyond the baseline broadcom code, what is the minm set of changes I should be taking from the tomato source to build it? Has any one tried it?
Again, appreciate the help!
I remove the .depend files and build it again.
rm -rf $(find . -name '.depend')
But as Tathagata said, you should check the toolchain version also.
Qos is by default enable in Tomato. you can disable the features which you dont want.
ok, so I can build the code on a Fedora 6 machine finally without any errors. Thanks for the help!
Now my questions are:
1. This code is not the latest 1.23 from tomato. Where is the 1.23 source available?
2. On the current version in this thread, if you do
you can get tomato 1.23 from tomato site(http://www.polarcloud.com/tomato). But that is not ported for WGR614l.
Mona
What is the latest version that's ported over to WGR614L? How much of this Tomato source is under GPL? Who does the porting? Also, whats the difference between the tomato source and the WGR614L?
http://www.myopenrouter.com/download/10413/tomato_wgr614l-lzma/ is the latest published tomato firmware ported for WGR614l ported by Netgear team.
both the tomato and wgr614l source code are open source. So anybody can try this. Mainly you have to port brcm-boards in the path src/linux/linux/arch/mips/brcm-boards/
