Can someone explain as to how the % in bandwidth add up to greater than 100% in tomato Qos basic setting page? Also, can the Qos be controlled via CLI using say busybox?
Hi Roy,
It seems u have posted the same query at several places on this site ... :) ..anyways I have not seen any % for bandwidth in tomato QoS basic setting that extends beyond 100% .... In which case / parameter u r observing this value ...
QoS can be configured via CLI using nvram commands ... the parameters that can be set are qos_ack, qos_burste , qos_orates etc . ... just run a nvram show comaand on the board's console and search for the string "qos_" in the command out
put and u can see all qos parameters that can be configured through CLI/nvram ...
Good day,
I am new in networking,
It would be great help, if you could advice me below matter.
I have bought Netgear WNR3500LV2 and flash with Tomato open source firmware,
It is working perfectly, but we have 30 users,
Is it possible that i can set data limit (limit quota) 2GB per user in router.
appreciate ur help in advance .
Me too facing the same issue. Help out by adding more information.
