i would like to know if it is possible to install ipcop on a netgear WGR614L.
Thank you.
Tank you for your answer Tathagata,
I'm happy that it is possible, but i don't know how to do this.
I can found the source code of Ipcop easily in the official web site.
For the firmware, i don't know really which of these i can/must use.
Have you an idea ?
By the way, when the firmware will be installed, how can i put ipcop on it ? (shh access, usb stick ? or something else ?)
Thank you.
thank you very much for helping me,
the IPCop code source may be found here :
http://sourceforge.net/project/showfiles.php?group_id=40604&package_id=3...
But IPCop is not a simple application, it is a linux distribution and curiously has a makefile when you retrieve the source... (don't understand why).
and when you install it, it begin by formating the hard drive. (so the firmware i suppose)
That's why i don't know if is it possible to instal both.
i hope you can help me.
i am using ipcop since 7 yrs and it's performing well.. i also tried openwrt..
IT will be amazing if ipcop can port and work from WGR614L..
IPCOP is damn best open source firewall and WGR614L is a opensource router.. please guide how to do it
