Can this be done? I got a WNR2000, hoping I could now use both my WNHDE111's to connect to it as bridges. So far, no luck at all. Any suggestions?
this can be done if WNR2000 supports bridge mode and also if ur WNHDE111 supports client mode ... check these things and then it can be done ..
Let me know if u have any doubts .. :)
this wont work, WNR2000 is on 2.4ghz and the WNHDE111's at 5ghz. they wont see each other
As another poster pointed out, the WNR2000 is 2.4ghz only, while the WNHDE111 is 5ghz only.
I returned the WNR2000 and got a WNR3300 -- now it's working fine. ;-)
For the WNR2000:
stock username: admin
stock password: password
To get the user guide, go to google.com and search for the following:
"Congratulations on your purchase of a NETGEAR high-speed wireless router, the Wireless-N. Router Model WNR2000. Before you begin installing your router"
Do not include the quotes.
It will pop right up in Google! I tested it just now. However, I had to click "View as HTML", because the pdf file didn't work. This means it may not be up for much longer.
Hope this helps and good luck!
Sincerely,
Scott Calvin a.k.a. KillerNumberX
http://Youtube.com/KillerNumberX
http://GodfatherPoints.com
and many more...
Dear miaczynski46,
You may have been sabatoged. I suggest you destroy all computers immediately, or tomorrow you may die, due to your own spontaneous combustion.
Just kidding. However, without being there and seeing it, there is little I can do to help. It will be helpful if you do some screenshots (ctrl+prt scr), and then upload them to the web, somewhere like imageshack.us, that's what I always use, and then copy the links, and place the links in a comment here so I can look at what's going on and help you troubleshoot.
Sincerely,
and many more...
