AS there are many Firmware versions available for the WGR614v8, and latest updates are available, can anyone tell me that how could i know the difference between the firmware versions.
e.g what is the additional facility in v1.1.11_6.0.36 which the versions prior to that didn't have.
Can i get such information for all the firmware versions available?
Secondly ... does anyone know about the format of the version number that why we write it as:
1.1.11_6.0.36 or v1.1.2_1.0.23
what format are they following to change the version number.
U can have a look at the changelog for different versions .....
As far as convention for version numering is concerned no one but netgear can answer that ....
Actually the reason behind my question is that the company in which i am working wants me to use the same naming convention that netgear is using.
Therefore I am confused that what version number i should write when i will change my firmware.
As i have mentioned 2 different version numbers i.e 1.1.11_6.0.36 or v1.1.2_1.0.23.
I wonder why one start with 1.1.11 and the other with 1.1.2 (not 1.1.12)
and in the same way end with 6.0.36 and the other with 1.0.23.
Thanks a lot.
That is the information I was looking for :)
