Is there anyone done it?
apart from broadcom DD-WRT supports other platforms like :
ralink, atheros etc.
You can have a look at the following link to get a detailed info:
http://www.dd-wrt.com/wiki/index.php/Supported_Devices_802.11n
If ur intended platforms is one of them then it can be done otherwise u will need to add support for ur platform to DD-WRT (which is not an easy task .....)
Thank you for your help!
I want to port DD-WRT to a marvell's network CPU platform etc. and on this basis, to achieve the basic functions of DD-WRT.
Of course, I am in no hurry to achieve the wireless function. Just port it!
How should I do?
It's a very interresting idea because a lot of routers are Marvel based (like the Netgear WNR3500 v1 for example).
Any news ?
