I downloaded the binary of dd-wrt for WNR3500L routers on this website and tried to flash my WNR3500 (not L) router with, but this failed.
It seems it needs another specific binary. Where can I find it ?
Regards
Regards
You may try this untested one if your non-L router is at least a V2.
Thanks a lot for this very interresting link, but unfortunately my WNR3500 is a v1.
Do you know if it's possible to find a dd-wrt firmware for this model ?
Best regards.
No chance, the V1 is on the blacklist and there's no subdirectory in the download area (L & V2 only).
Thanks a lot Schugy,
I saw on this blacklist that the WNR3500v1 is not supported because it has a Marvell chipset inside, but I saw these chipsets could be supported in the future.
I hope it'll be.
Regards
