WNR3500L; Netgear Firmware Flashing
7 posts / 0 new
Hotzenplotz
Hotzenplotz's picture
hey guys
i've an wnr3500l.
so, i flashed him with dd-wrt.the wireless isnt' good yet, I think.
so i will flash the original firmware to my router.
netgear gives chk files but dd-wrt supported no chk file flashing...
what to do fpr flashing original firmware on wnr3500l based dd-wrt.
sorry for my english -.-
bye
nukie
nukie's picture
Wich version did you use?
Wich version did you use? There are a new build here:
http://www.dd-wrt.com/site/support/other-downloads?path=others%2Feko%2FV...
But read the "readme.txt" first.
nukie
nukie's picture
Double post...
Double post...
Hotzenplotz
ftp://dd-wrt.com/others/eko
ftp://dd-wrt.com/others/eko/V24-K26/svn13491-snow/Netgear/WNR3500L/
This version...
I will flash the original firmware. Perhaps there is a better wireless performance yet...
but netgear only gives *.chk files
bas_der_gruene
bas_der_gruene's picture
-deutsch-
-deutsch-
Hallo Hotzenplotz,
hier hab ich das gleiche Problem. Ich möchte gerne zur Original-Firmware zurück, aber für DD-WRT ist keine .bin-Datei vorhanden. Hast du eine Lösung gefunden?
-english-
Hello Hotzenplotz,
I do have the same problem. I would like to switch back to original firmware, but there ist no .bin-file for uploading with dd-wrt. Did you find a solution yet?
Brandon C
Brandon C's picture
Basically you need to remove
Basically you need to remove the DD-WRT firmware and put the Netgear firmware back on.
Here is an article on how to do that.
http://www.myopenrouter.com/article/10496/How-To-Switch-Firmwares-on-the...
Hotzenplotz
thanks. it works fine :-)
thanks.
it works fine :-)
