OK to upgrade to other versions?
5 posts / 0 new
Mainer82
Mainer82's picture
I have the "dd-wrt.v24-13309_NEWD-2_K2.6_big.bin" version installed on my 3500L. Am I supposed to watch the router database page for newer versions? Or can I install the latest build from the broadcom chip? Is that safe?
 Thanks in advance
Brandon C
Brandon C's picture
Pretty much after you have
Pretty much after you have upgraded to DD-WRT any version is safe. Meaning it probably won't brick your router. If they don't work as expected you can always revert back to an older firmware.
Mainer82
Mainer82's picture
How do I find the download
How do I find the download area for the broadcom version? I'm not sure where to look. Thanks,
Brandon C
Brandon C's picture
Click on the downloads tab
Click on the downloads tab above and then go to the WNR3500 > DD-WRT list. This will show you the latest firmwares for the WNR3500 which uses the broadcom chip.
Mainer82
Mainer82's picture
Why doesn't the main DD-WRT
Why doesn't the main DD-WRT page update their listing to the one on this site?
