WNR3500L My printer is not recognized
10 posts / 0 new
Pastill
Pastill's picture
I've installed dd-wrt, downloaded from this site.
Trying to install a printer.
Following Wiki http://www.dd-wrt.com/wiki/index.php/Printer_Sharing and more support in http://www.dd-wrt.com/phpBB2/viewtopic.php?t=63095&highlight= I got everything (?) working except that router don't recognize/mounts USB-printer.
With command "dmesg | grep usb" I get result:
root@PS:~# dmesg | grep usb
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
usb usb1: configuration #1 chosen from 1 choice
usb usb2: configuration #1 chosen from 1 choice
usbcore: registered new interface driver usblp
usb 1-1: new full speed USB device using ohci_hcd and address 2
usb 1-1: device descriptor read/64, error -62
usb 1-1: new full speed USB device using ohci_hcd and address 3
usb 1-1: new full speed USB device using ohci_hcd and address 4
usb 1-1: device not accepting address 4, error -62
usb 1-1: new full speed USB device using ohci_hcd and address 5
usb 1-1: device not accepting address 5, error -62
p9100d Service is running, lp0 node exist and listening to port 9100.
PC don't report any error. Send print OK.
But nothing on printer.
Printer is a HP OfficeJet with a parallel cable converter. ( it all worked with a wl-500gP and Oleg's fw incl. recognize printermodel, also running p910nd).
Firmware now on my WNR3500L is dd-wrt.v24-13401_NEWD-2_K2.6_std_usb_ftp.bin.zip
Here is result from checking of services:
root@PS:~# mount | grep -i jffs
/dev/mtdblock/4 on /jffs type jffs2 (rw)
root@PS:~# ls -l /jffs/usr/sbin/
-rwxr-xr-x 1 root root 8563 Mar 26 2006 p910nd
root@PS:~# ls -l /dev/usb
crw-rw---- 1 root root 180, 0 Jan 1 1970 lp0
root@PS:~# ps | grep p91
956 root 640 S p9100d -b -f /dev/usb/lp0 0
root@PS:~# netstat -an | grep 910
tcp 0 0 0.0.0.0:9100 0.0.0.0:* LISTEN
Searching on google no errorcode 62 is found, but with similar type of error a lot of people say it's a kernel problem.
Solution ?
ndlarsen
ndlarsen's picture
Try it out with the latest
Try it out with the latest revision.
Pastill
Pastill's picture
It is the latest as I can see
It is the latest as I can see it. 13401
Or is there any other later svn's for WNR3500L some other places ?
ndlarsen
ndlarsen's picture
http://www.dd-wrt.com/site
http://www.dd-wrt.com/site/support/other-downloads
Browse to: others > eko > V24-K26 and there is a dir list of revisions.
Currently rev. 13575 is the latest.
Regards.
Pastill
Pastill's picture
Installed dd-wrt.v24-13575
Installed dd-wrt.v24-13575_NEWD-2_K2.6_std_usb_ftp.bin
But same result. Everything exactly as before:
and nothing on printer.
ndlarsen
ndlarsen's picture
Which USB related services
Which USB related services have you got enabled in the web UI? (Services > USB)
Pastill
Pastill's picture
I have all but Storage
I have all but Storage support.
But I tested more.
If I reboot without printer connected and later connect printer cable it now works. Printing OK.
USB needs to be delayed or something in startup ?
How ?
Pastill
Pastill's picture
Tested more.
Tested more.
Reboot again, but now with cable connected.
And now it works directly.
Printer recognized.
All it needed after new fw was apperently a kind of removing some values.
Now it says:
usb 1-1: configuration #1 chosen from 1 choice
usblp0: USB Bidirectional printer dev 2 if 0 alt 1 proto 2 vid 0x067B pid 0x2305
Thank you for the tip.
lanaserena
lanaserena's picture
To solve this issue, I will
To solve this issue, I will suggest you to restart the printer.Second step is to check the connection issue.If the printer connected via USB cable, make sure it is not damaged.If it is then replace with a new one.Now check the network connection.That's how i solved the same issue.Since you are using printer i would like to provide you and added information you might face an error code 0x97 problem which is very common in general,it will occur all of a sudden with no early sign.No need to worry just read a blog epson error code 0x97 and follow the steps accordingly.The problem will get solved.
jhonson1212
jhonson1212's picture
For the issue of WNR3500L
For the issue of WNR3500L printer is not recognized, you can reset the the printer firstly and then reinstall the printer driver from disk that is given by the manufacturer, your problem will be solved. For any information you can directly contact us on Facebook
