WGR614 V8 and DD-WRT update
9 posts / 0 new
Tysek
Tysek's picture
hello Everyone
Couple days ago I bought my first open router ( I use Linux a few years)
But os. for routers is for me black magick :( (at the moment)
I install DD-WRT from this guide,
but yesterday i saw on page dd-wrt that exist new os. for my router.
I read this (Upgrading to a Newer Version of DD-WRT)on DD-WRT wiki.
Please  tell me with version ( and extention bin/chk)    I must chose (home network, 3 clients it's, ssh) and how  update my WGR ?
Thanks a lot
Brandon C
Brandon C's picture
If you already have DD-WRT on
If you already have DD-WRT on the router then use the BIN file shown for your router version. The Micro version BIN file should do what you need.
achilles
achilles's picture
Also it would be better to
Also it would be better to use IE for f/w upgrade instead of firefox ...... you can upload MINI version of the build also (it would provide some extra features)...
Make sure that if u have a DD-WRT f/w running on ur board , u use .bin file for upgrade and if u have default netgear f/w running on ur board u use .chk file for upgrade ...
Tysek
Tysek's picture
After update i heve problem
After update i heve problem power led blinking.
I make 30/30/30 reset.
On dhcp can't get Ip adres (by cable rj45)
If I set manual 192.168.1.1 and mask 255.255.255.0, my computer connected to router.
eth0 Link encap:Ethernet HWaddr 00:1c:23:89:a3:4f
inet addr:192.168.1.1 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::21c:23ff:fe89:a34f/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:70939 errors:0 dropped:0 overruns:0 frame:0
TX packets:64958 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:24449805 (24.4 MB) TX bytes:9591419 (9.5 MB)
Interrupt:17
Ping
PING 192.168.1.1 (192.168.1.1) 56(84) bytes of data.
64 bytes from 192.168.1.1: icmp_seq=1 ttl=64 time=0.042 ms
64 bytes from 192.168.1.1: icmp_seq=2 ttl=64 time=0.066 ms
64 bytes from 192.168.1.1: icmp_seq=3 ttl=64 time=0.047 ms
64 bytes from 192.168.1.1: icmp_seq=4 ttl=64 time=0.064 ms
I try try by tftp
tftp binary 192.168.1.1 -c dd-wrt.v24_mini-wgr614v8-L.chk
after this my system give me this: usage: tftp host-name [port]
I sterted tftp olny with adres "tftp 192......"
and give this order. but nothing happens
tftp> binary -c /home/tysek/Dropbox/rezurekcja/WRT614L/dd-wrt.v24_mini-wgr614v8-L.chk
tftp>
What should I do ?
Brandon C
Brandon C's picture
Set your computer's address
Set your computer's address to something like 192.168.1.10, 255.255.255.0 and gateway to 192.168.1.1.
Then try to ping, tftp to 192.168.1.1
Tysek
Tysek's picture
I give update to my post.
Brandon C
Brandon C's picture
I assume you are running
I assume you are running Windows.
To TFTP you need to enter
tftp -i 192.168.1.1 PUT yourfirmware.chk
the -i after tftp tells it binary and then the adress or your router, then "PUT" tells it to send the firmware you name onto the router.
Tysek
Tysek's picture
Thanks for your help and time
I'm using Linux, but i quickly install XP, and tftp, It works :-)
I don't know why i wasn't working in Ubuntu.
Thanks a lot
Brandon C
Brandon C's picture
Suweet! Glad you go it
Suweet! Glad you go it working. Rock on!
