Static DNS killed DD-WRT (13491 big)
3 posts / 0 new
djohnson438
after adding static DNS IP addresses my WNR-3500L died (DHCP/WAN/Wireless/telnet stopped working).
on power up I get a 30 second window where it will respond to pings, then all lights except power flash green for 1 second and it goes into a coma.
tried tftp (several times) as soon as i get the first response ping, but no luck there either.
i have a pl-2303 cable (3.3v) and soldering iron, but would like to find an easier way if at all possible..
djohnson438
..found out I can send files
..found out I can send files to it via tftp server (start tftpd32, rename a .chk/.bin file to "vmlinuz").
not sure if this is helpful though as both micro and stock firmwares transfer successfully, but nothing happens on the router.
djohnson438
I fixed it!
I fixed it!
just needed to hold reset button while plugging power in.
