Hey guys, I just got my wnr3500L. The original plan was to run the tomato. I managed to get dd-wrt installed from the netgear firmware (v24 sp2 mini).
The next step was to install tomato. But i got the "incorrect image file" error. So i tried to upgrade to another (older version) but, I still get the same error.
I tried to upgrade back to the netgear software, but it gives the same error as well. What am I doing wrong?
I figured it out. I was using firefox to update the firmware. Turns out internet explorer worked.
Thank you for posting your fix. it helped me
