Here is the error I get when my wgr614 is booting:
WGR614v8 - 1.5 (Fri Jun 6 15:53:24 CST 2008)
Device eth0: hwaddr 00-FF-FF-FF-FF-FF, ipaddr 192.168.1.1, mask 255.255.255.0
Loading: Failed.
Loading ..
CPU ProcId is: 0x00029029, options: 0x0000004d
Linux version 2.4.37 (root@dd-wrt) (gcc version 3.4.6 (OpenWrt-2.0)) #7581 Sat Oct 10 01:29:13 CEST 2009
Determined physical RAM map:
On node 0 totalpages: 4096
zone(0): 4096 pages.
zone(1): 0 pages.
zone(2): 0 pages.
Kernel command line: root=/dev/mtdblock2 rootfstype=squashfs,jffs2 noinitrd console=ttyS0,115200
CPU: BCM5354 rev 2 at 240 MHz
Using 120.000 MHz high precision timer.
Calibrating delay loop... 239.20 BogoMIPS
Mount cache hash table entries: 512 (order: 0, 4096 bytes)
Buffer cache hash table entries: 1024 (order: 0, 4096 bytes)
Checking for 'wait' instruction... unavailable.
PCI: no core
PCI: Fixing up bus 0
Starting kswapd
devfs: v1.12c (20020818) Richard Gooch ([email protected])
devfs: boot_options: 0x1
Serial driver version 5.05c (2001-07-08) with MANY_PORTS SHARE_IRQ SERIAL_PCI enabled
ttyS01 at 0xb8000400 (irq = 3) is a 16550A
PCI: Setting latency timer of device 00:01.0 to 64
PCI: Setting latency timer of device 00:05.0 to 64
sb_doattach: incoming bus is PCI but it's a lie, switching to SB devid:0x4318
PPPoL2TP kernel driver, V0.13
Universal TUN/TAP device driver 1.5 (C)1999-2002 Maxim Krasnyansky
sflash not supported on this router
Initializing Cryptographic API
ip_conntrack version 2.1 (512 buckets, 4096 max) - 336 bytes per conntrack
ipt_random match loaded
netfilter PSD loaded - (c) astaro AG
ipt_osf: Startng OS fingerprint matching module.
ipt_IPV4OPTSSTRIP loaded
802.1Q VLAN Support v1.8 Ben Greear
All bugs added by David S. Miller
VFS: Cannot open root device "mtdblock2" or 1f:02
Please append a correct "root=" boot option
Kernel panic: VFS: Unable to mount root fs on 1f:02
<0>Rebooting in 5 seconds..Please stand by while rebooting the system...
Decompressing..........done
Before it crashes, it has been runing ddwrt Build13064 for at least 3 months.
After reading many posts, I tried to send an official firmware (wgr614v8_1_1_1_1_0_20_na.chk) :
CFE> ^C
CFE> iFconfig eth0 -hwaddr=00223F22B144 -Addr=192.168.1.1
Device eth0: hwaddr 00-22-3F-22-B1-44, ipaddr 192.168.1.1, mask 255.255.255.0
command status=0
CFE> nvram set boardid=U12H073T00_NETGEAR
command status=0
CFE> nvram set boardtype=0x048e
command status=0
CFE> nvramset boardnum=01
command status=0
CFE> nvram set boardrev=0x11
command status=0
CFE> Nvram set boardflags=0x750
command status=0
CFE> nvram set boardflags2=0
command status=0
CFE> nvram commit
command status=0
CFE> tftpd
Reading :: Done. 3268666 bytes read
Reading ::
And nothing happens...
Could you help me please?
I have never tried to do it after setting all the parameters you did above.
Maybe just get to the CFE prompt and run TFTPD and see what it does.
Before trying to set all parameters, I tried just setting mac address and then tftpd, but the result was the same...
Good news!
I've downgraded to CFE 1.3...
And I've just flash my router with netgear ROM!
Glad you figured it out.
Had you upgraded the CFE previously and that is why you had to downgrade?
No, the original CFE was in 1.5
Maybe the problem with 1.5 is: you can't use setenv command. But when you fash a firmware, boardid is verified.
http://www.myopenrouter.com/forum/thread/10709/CFE-1.5-Question/?highlight=cfe+1.5
For my problem, boardid seemed not existing.
I see typos in the transcript:
Should be "board_id" ?
Should be "U12H072T00_NETGEAR" ?
Was tftp transfer in binary?
