I lost the security keys (#'S) Now I want to add a new computer. What can I do?
MyOpenRouter.com is not affiliated with NETGEAR®. NETGEAR is a registered trademark of NETGEAR, Inc. in the United States and/or other countries. Other brand names mentioned herein are for identification purposes only and may be trademarks of their respective holder(s). © 2020 All rights reserved.
What firmware you using? would be helpful..... on dd-wrt though its like this...
either 2 things, hard reset your router and start again from scratch...bummer!
or if you can telnet to the router you should be able to get your info from looking at the processes. should look something like this.
105 1 root S 1584 5.4 0.0 resetbutton
567 1 root S 1532 5.2 0.0 nas -P /tmp/nas.wl0lan.pid -H 34954 -l br0 -i eth1 -A -m 128 -k 1t2w3g4r5h6 -s dd-wrt_g -w 4 -g 3600
317 1 root S 1508 5.1 0.0 process_monitor
as you see line 567 shows your password, not a security problem so long as your the only admin with telnet access.
Thanks I'll give it a try. If not I'll do the hard reset.
