Hello-
I have a couple of WNR2300 routers running DD-WRT. For some reason they can not access web site that are running flash content. Everything else is perfect.
Does anyone have a soultion for this?
Router details:
WNR3500v2/U/L
DD=WRT v24-sp2 (11/25/09) mini build 13309m NEWD-2 K2.6 Eko
Thanks for your help!
The same router,
FW - DD-WRT for WNR3500L v24 K2.6 svn14289 Big (BIN) BETA.
Control panel is not accesable. Any idea?
Regards
I don't have any issues accessing the control panel but I am running the "mini" non-beta version. You may want to try a "non-beta" release.
There is no "non beta" FW. Look at: http://www.myopenrouter.com/download/list?sort=date&cat=48
All FW are beta's stauts.
Some other link?
Regards
I doubt, this is a router problem. You are probably using some kind of blocker noscript for firefox, firewall like kaspersky etc.
The router itself is not able to block flash conent at least not with standard firmware.
Kong,
Thanks for the tips and I tought the same thing but it doesn't matter what PC/laptop I try to use. I had guests come in and try with different computers/OS and they all have the same issue.
I do have Kaspersky on my network. Though my desktop (different router/firewall) I don't have any issues. But when trying to go though one of these routers I do. I used different computers and they all have the same issue.
So far I have turned off some of the filters and it has seem to resolve the problem somewhat. But I still have some issues.
z-ka,
Go here: http://www.dd-wrt.com/site/support/router-database
then enter the model of the router.
Thanks for help. But I have question before installation proces. Should I reset WNR3500L to factory settings before or can I just overwrite settings? How It suppose to be?
Regards
It is recommended that you reset your router before installing a new firmware. See here on options. http://www.myopenrouter.com/article/18623/How-to-Hard-Reset-Your-NETGEAR...
Thanks Brandon,
Regards from Belgium
Hi all,
Yesterday I replaced beta FW from this site to stable version from DD-WRT site and today I have the same problem. I can't log into Control Panel. I have no idea what to do right now and what is causing this problem. Roter works ok exept as I described above. I installed dd-wrt.v24-13309_NEWD-2_K2.6_big.bin
Any idea?
That's an old version of DD-WRT that's known to have problems. Try r14289 which I'm running on mine. Do follow the instructions to avoid problems such as those you describe.
@whodo If you still have issues, then I recommend to use a network sniffer/analyzer "Wireshark" With this tool you can find out if there are connection/network configuration problems etc.
A simple test you could also reveal problems:
http://help.expedient.com/broadband/mtu_ping_test.shtml
If you can capture a few sec (with wireshark) while trying to access a non working site. You can upload it somewhere and I'll take a look at it.
Yes, try this tool, it comes with both command line and GUI versions. How you install it will depend on which version of Linux you're using - you'll almost certainly be able to install it through your distro's package manager.
hello.I see you are using Kasperky antivirus and I am very glad because i can recommend you top ten best antiviruses http://www.best-antivirus.co/
hope it will help you
