Enable VLAN of ID 100
5 posts / 0 new
nockawa
Hi all,
Firstabel I'm no expert in network stuff, so please be indulgent.
My issue is I have two kind of data coming from my internet connexion into my router: regular internet packets and packets tagged with a VLAN ID of 100. The later one are totally blocked by the router!
I changed the firmware of my WNR3500L to the DD-WRT hopping to find a way to enable those packets to be routed to a given ethernet port of the router, but I couldn't succceed...
 Any help will be greatly appreciated as I'm getting mad (and sleepless) to solve this issue.
 Regards
autobot
According to LOM on DD-WRT
According to LOM on DD-WRT forum Broadcom's switch IC's does not support vlan tags above 15.
nockawa
thanks you so much for this
thanks you so much for this answer, I finally understand why I couldn't get this done! I can rest in peace now! :)
doudi76
did you found a solution to
did you found a solution to activate VLAN of ID 100 on WNR3500L ? Please help me.
I need to connect my PCH-C200 on my WNR3500L to work with my FreeBoxHD for UPnP.
nockawa
nope you can't get it done. I
nope you can't get it done. I didn't check if there's a new version of the firmware but with the one I have it's impossible.
