can you advise me with acces to FTP?
There is not problem when I connect to FTP from local network (IP 192....) but if I want to connect to FTP via internet it is not possible. I read and set router according to guide ( http://www.dd-wrt.com/wiki/index.php/ProFTPd ) but still it is not working.
I use firmware from kong - DD-WRT BETA svn 14584 with Samba3 for WNR3500L
Thank you
Hi cz_coxx,
I have just tested remote access. Once you run:
/usr/sbin/iptables -I INPUT 1 -p tcp --dport 21 -j logaccept
it should work. What FTP Client are you using?
Have you tested using filezilla: http://portableapps.com/apps/internet/filezilla_portable
You should also check if the directory you specified in ProFTPD Settings has the correct permissions to allow it to read from it.
I tested your command and now it works great.
Permissions was correct, there was problem with IPTABLES
Thank you
Never mind
