I bought a Sony BDP N460 Blu Ray player. I am trying to get it hooked up to my wireless network. It says I need a wireless hub or something like that. Netgear says I can use my WRN3500L router as a hub but they are taking way to damn long to reply!
How can I set it up? I am not the greatest with networking etc so if someone can use easy to understand lingo or step by step directions I would appriciate it!
The Sony BDP N460 does not have built in wireless. So you are going to need to purchase additional hardware if you want to go wireless. Something like this: http://www.amazon.com/Cisco-Linksys-Dual-Band-Wireless-N-Gaming-Adapter/...
You can use the WNR3500 as a hub or wireless bridge. If you set it up that way you won't be able to use is as a regular router at the same time.
Here is an article on setting up the WGR614L as a wireless bridge.
http://www.myopenrouter.com/article/16337/Using-NETGEAR-WGR614L-with-DD-...
The WNR3500 is setup the same way.
If you are using the WNR3500 as a regular router then you need to get something like the WNHDE111 Wireless-N Bridge.
http://www.myopenrouter.com/article/10274/Data-Sheet--WNHDE111-Wireless-...
So if I buy something like the Cisco Linksys Gual Band adapter, all I have to do it configure it to see the wireless and run an ethernet cable from the adapter to my blu ray?
Exactly
Netgear also has this device that will work with your BluRay player: http://www.netgear.com/landing/en-us/wnce2001.aspx
