Another Update for my Minidlna/Samba3/USB/FTP DD-WRT Mod
4 posts / 0 new
Kong
Hi guys,
after a few days testing, there is a new Build of my dd-wrt mod.
New:
  • added webif setting for minidlna to allow db update interval setting, default is 60s
  • compile optimized
  • improve wan-lan routing performance
Fixed:
  • large filesupport now working (tested) for samba and busybox console utils(ls,rm etc.)
Removed:
  • nfs modules, due to image size, eventually I'll add them in a seperate build + nfs-utils
Known Issue:
  • proftpd reports wrong file size for files >4GB, this does not affect the actual transfer of files >4GB
Download
@peter, as always please update the file in the download section
Kevin Mahoney
Hey Kong,
Hey Kong,
Looks like there is an error in your startup script for samba3.
if [ "$(nvram get samba3_usr2)" != "" ]; then
grep -q $USR2 /etc/passwd || echo $USR1":*:1000:1000:"$USR2":/var:/bin/false" >> /etc/passwd
smbpasswd $USR2 $PASS2
fi
Should be?
grep -q $USR2 /etc/passwd || echo $USR2":*:1001:1001:"$USR2":/var:/bin/false" >> /etc/passwd
fi
Kong
Good catch!
Good catch!
I'll update it. Actually I think I should change those edit fields and use a text box with user:pass style as in proftpd. That would allow to add more users.
Kevin Mahoney
Some feedback:
Some feedback:
- I like the idea about adding additional users however I don't like how the password is displayed in plain text. We really need a whole interface maybe as a part of sshd configuration for handling extra users. Having root exposed to the world isn't the best security measure.
- Make a simlink from /etc/samba/smb.conf -> /tmp/etc/smb.conf and use /etc/samba/smb.conf
- Grepping /etc/passwd for a user name is proned to problems
if user10 existed in /etc/passwd
grep user1 would return 0 and user10 wouldn't be added to /etc/passwd
