Ditched DDWRT and went to tomato
6 posts / 0 new
SirDragonx
Ok I have to admit that I am a DDWRT fan because of it's tons of features but have had stability issues with My Buffalo Router and speed issues with the WNR3500L and I just couldn't get OpenVpn to work on DDWRT.
I always wanted to try tomato because I have heard it was so stable and also heard OpenWrt was also as stable.  only problem is that the tomato builds here did not have VPN support and I didn't want to get in to the weeds with OpenWRT.  I did some searching and found an awesome build of Tomato with OpenVPN support and it works like a charm with my VPN service.
Sorry, I love DDWRT for all it's features but I have had nothing but problems with stability!  Tomato is so much easier to configure and with the mega build that I found it has everything I need to include USB support and OpenVPN support.
I posted an installation thread with a link to Tomato build.
I guess I should say cya DDWRT and mybe I'll come back when your firmware is as stable as OpenWrt and Tomato.
If I wanted to create a hot spot maybe I would go back to DDWRT but other than that Tomato has what I need and actually works!
SirDragonx
The installation thread is in
The installation thread is in the Tomato forums.
Kong
If you had speed issues, then
If you had speed issues, then you probably didn't use my optimized dd-wrt mod, which is faster than tomato. I have not heard of any stability issues with my releases. In fact my WNR3500L has been running for month without any problem.
I have seen a few bug reports regarding openvpn with frequent disconnects but they always turn out to be setup problems, wrong mtu settings etc.
Anyways I still have to release another dd-wrt mod with openvpn that includes my enhancements
SirDragonx
I had slowdown problems and
I had slowdown problems and when I have the router under heavy use the wireless disconnects for a few seconds constantly. While surfing the net this is ok but when you are playing games online you get disconnected. I had even worse problems with my bufallo router.
I have heard good things on this site about your mod. Once I found tomato was so much more solid I just switched. I am a geek but with my current job, I don't have time to tinker as miuch as I like. Tomato is just more stable and hassle free. if I had the time to tinker maybe I'll go back.
Kong
SirDragonx said: I had
SirDragonx said: I had slowdown problems and when I have the router under heavy use the wireless disconnects for a few seconds constantly. While surfing the net this is ok but when you are playing games online you get disconnected. I had even worse problems with my bufallo router. I have heard good things on this site about your mod. Once I found tomato was so much more solid I just switched. I am a geek but with my current job, I don't have time to tinker as miuch as I like. Tomato is just more stable and hassle free. if I had the time to tinker maybe I'll go back.
The wireless issue may have been a result from the higher tx power dd-wrt initially sets up. Lots of traffic then causes overheating especially if the ambient temperature is high. I always recommend to lower the value as much as possible.
Roflcat
What's ironic and funny is I
What's ironic and funny is I am in the other boat. I am having speed and WAN IP issues with Tomato on my 3500L and hoping to find better luck with the DD-WRT (been with Tomato for over 4 years >
