I re-set my router and want to delete it from my computer and start over with the disk - the more I try the worse it gets. I'm blond and clueless... Please guide me :) I'd like to delete the whole thing and begin fresh. Thanks for your help, Bama
It z not clr 2 m3 wat exctly u intend 2 do ... It seems to me that u want to do a f/w upgrade ... if this be the case use the GUI interface to do this ...
Do remember to use IE for this ... if this z not wat u wanna do then let me know with some details ...
push button default or do it from router configuration page that's all than all options will be reset to default . note that also router username and password will be reseted to default you can find router usernames and password here wireless router review
Finally, got what I was looking for!! I definitely enjoying every little bit of it. Glad I stumbled into this article! smile I have you bookmarked to check out new stuff you post
electric beds
