Cannot ping router :(
3 posts / 0 new
josip
I followed this howto:
http://www.myopenrouter.com/article/16099/How-To-Reflash-Factory-Firmwar...
and now cannot ping my router.
What can I do now before buying a serial cable?
Peter Redmer
So, to clarify, you had DD
So, to clarify, you had DD-WRT on your router previously, tried the tutorial to return it to the NG factory firmware, and now you can't ping it?
If all that is correct, have you tried a 30-30-30 reset? That would be the first thing I would try.
http://www.myopenrouter.com/article/18623/How-to-Hard-Reset-Your-NETGEAR...
All in all, though, if you're going to be installing/changing firmwares, a serial cable is truly indispensable.
Kong
Before I got a JTAG Adapter I
Before I got a JTAG Adapter I used the short pin method which, see my comment here:
http://www.myopenrouter.com/forum/thread/21535/Can-t-restore-stock-firmw...
