I have has legacy on my network since upgrading to ddwrt from factory. I now unable to stream HD MP4 movie across my network.
So I will either try Tomato or factory I was wondering what is the best way to go from ddwrt to tomato software and is hard to go from tomato to factory
I stand corrected it is not DD-WRT causing issues on my network I have internet connectivity issuse not the router. i am getting packet loss on the internet.
However I already upgraded to tomato will try this for awhile Got 1 question.
once again my slingcather says it is writeproteced how do I enable read/write on tomato
any update on how to make a drive read/write I tried everything
You pics are too small to see everything. Can you read write in Windows?
If you right click on them in Windows and then properties what does it show you?
Something like \\Unknown\sda2 ? If so try that address.
I think it is only the slingcatcher cause I can cut a paste and delete files from a PC. Both of my Catchers say on tomato write protected on DDWRT everything was working then the drive no longer would mount on OEM netgear I keep getting server invalid \\READYSHARE\USB_Storage WTF
