Hi folks,
here comes another update of my dd-wrt mod. It is now based on dd-wrt r15510.
New:
- VLAN gui setup support
- textfield to set a identification string for the dlna server
- textfield for default samba share path
- dns rebind option to enable/disable rebind protection
- new hotplug mechanism
- proftpd update
- openvpn update
- lots of small fixes/enhancedments from upstream
Fixed:
- minidlna db creation when first used
- dyndns bug
- fix out of mem issue that can causes new connections wireless/wired to fail
dd-wrt-usb-ftp-samba3-dlna-O2-v24-K26-broadcom.bin
MD5 Checksum: 609bb815863f233f3634bbaf4928fcb3
dd-wrt-usb-ftp-samba3-vpn-O2-v24-K26-broadcom.bin
MD5 Checksum: 9e4c9be45c6b790e0dad637179e645f7
Planned for next release:
- integration of nfs-utils
Note:
If you have more then 3000 media files (photo,video,music) you should locate minidlna's db outside of the routers ram, therefore use the db path textfield under minidlna setup page.
@Peter, you can update the downloads in the download section again:-)
What type of checksums are they? Is it a md5 checksum?
Oh man, I can't wait for the next release. NFS-Utils is going to be a great addition. Any idea when you're pushing it out?
Yes md5 checksums. NFS support should be in there within the next 4 weeks.
Thanks Kong, I'll get this updated shortly. Once again, many thanks from myself and the community for your hard work!
Cheers,
Pete
Service ---> Proxy isnt working. Please fix!
Hi wischmasterf, yes I have to deactivate that tab in minidlna version, since minidlna does not include the proxy.
So to flash this I just have to do the 30-30-30 reset and then go to upgrade tab if I'm on ddwrt?
Has anyone flashed this and can assure me that it works? Last two times I tried flashing kong it got two bricks I tried on two different wnr3500l routers.
Can't wait to see nfs-utils. Thanks very much for the hard work!
i never had any problems with the same router...
So this build isnt based on that build: http://www.myopenrouter.com/forum/thread/23191/Kong-Mod-Updates/ ?
Is there a chance to get privoxy include in that build?
No privoxy is not included in the dlna build, but in the vpn build.
Whats the reason for two different builds?
Just wanted to say THANKS Kong for all your hard work for the entire community !!!
I started using your last OpenVPN release and it's fantastic. looking ff to your next release. the router is extremely stable and the features are great.
I'm using Netgear 3500L.
anyone notice that pptp server seems to be broken in this new build. have cleared nvram, reset, tried reconfiguring from scratch. pptp server is not allowing any connections that were connected on previous build.
hmmmm maybe it's not Kong or DD-WRT. This is odd. Is there a chance that PPTP could be broken from a hardware perspective. I have downgraded to known good versions of DD-WRT, erased nvram, hard resetted, reconfigured and still no VPN clients getting through. Called ISP to confirm there has been no blockages but don't know if I believe them. Very strange. I'll be setting up a different router to confirm if it's blocked from WAN side.
Is it possible to upgrade my netgear wndr3700 to whis firmware? Have tried for days now to install minidlna, but cant get it to work. It would be so much easier if your firmware worked on my router!
So, does it?
Hi leak,
no this build only works with broadcom 47xx routers(that don't need 60K nvram setting like the e3000) then wndr3700 has an atheros soc, since I don't own such a unit I don't compile and test such builds.
Thank you for the answer Kong. Dont want to mess up your thread, but your private message is turned off. So here it goes. Do you think its possible to compile my own minidlna for my wndr3700? Found minidlna in repo, but can only stream photos and music. Videos dont work. Google says it because libffmpeg is too "basic". And im kinda linux newbi. Once again, sorry if i mess upp this thread. Feel free to delete if so :)
Kong,
Any chance that I can get the source so that I can build it for a WNDR3700 and test? Happy to do it. I love the basic DD-WRT, but would love some of the features you have added, especially the minidlna.
-gglo
The source is not all you need, it needs a toolchain with a more recent uclibc, due to missing functionality in the current dd-wrt toolchains.
Providing my setup + sources would take me some time, since I cannot just commit my changes to the dd-wrt repository, which means it is difficult to just supply the diff.
Thank you for the information and quick reply. I understand. I am having trouble getting minidlna to work as it does with the Netgear release. Could you tell me all the packages you include in your release for minidlna? Do you have a list of all the packages you include in your mod?
Thank you,
-gglo
