Is there a way to install bitorrent or utorrnet on netgear rotuer with dd-wrt
Have a look at where your harddrive is being mounted at startup (make sure that automount option is enabled) I will use this as an example "/mnt/WDPassport"
Installation:
mkdir -p /mnt/WDPassport/opt
mkdir -p /mnt/WDPassport/Torrents
mkdir -p /mnt/WDPassport/Torrents/.incomplete
mount -o bind /mnt/WDPassport/opt /opt
wget http://www.3iii.dk/linux/optware/optware-install-ddwrt.sh -O /tmp/optware-install.sh
sh /tmp/optware-install.sh
/opt/bin/ipkg-opt install transmission
/opt/bin/transmission-daemon -g /mnt/WDPassport/Torrents/.config/transmission-daemon
killall transmission-daemon
wget http://www.3iii.dk/linux/optware/settings.json -O /mnt/WDPassport/Torrents/.config/transmission-daemon/settings.json
Configuration:
Now, edit "settings.json" file ("/mnt/WDPassport/Torrents/.config/transmission-daemon/settings.json")
Set the following:
"incomplete-dir": "/mnt/WDPassport/Torrents/.incomplete",
"download-dir": "/mnt/WDPassport/Torrents",
"incomplete-dir-enabled": true,
Save changes in this file.
Run transmission daemon:
Now you can access transmissions' web ui via http://192.168.X.X:9091
Enjoy :)
I you want transmission to be started automatically after your hdd is mounted add the below to your after-mount-script:
mount /mnt/WDPassport/opt /opt
Hope this helps :)
with replacing the WDPassport with my drive name
I also use jffs so just replace mnt with jffs
Do i run cmds via telnet
also what is tramision deamon
use SSH to connect to your router.
I have the latest TomatoUSB build 54 (http://tomatousb.org/download) installed on my WNR3500L and I had no enough free space left on JFFS to install the transmission deamon.
As I stated in the beginning of my first post, have a look where your HDD is mounted (dunno how to check it in DD-WRT).
If you have router with more than 8MB of flash memory like Asus RT-N16 (32MB) and want to install optware to JFFS change the following lines from the installation script (make sure that you enabled and formatted JFFS beforehand)
mkdir -p /mnt/WDPassport/opt -> mkdir -p /jffs/opt
and
mount -o bind /mnt/WDPassport/opt /opt -> mount -o bind /jffs/opt /opt
BTW: transmission deamon is another very powerful bittorrent client http://www.transmissionbt.com
not sure how to check the flash.
1 last question the bittorent does it have the ability to download rss torrents
1. if you want to check the amount of flash, go to this website and type the model of your router: http://dd-wrt.com/site/support/router-database
2. I don't think transmission optware supports donloading torrents via rss feeds.
ok thanks for all of your help
rss is what I am really want
When installing transmission-daemon you should also look at transmission-remote.
This program allows you to control transmission with a nice UI.
The benefit of this is you can set Transmission-remote to open .torrent files by default.
This makes the whole experience basically the same as having uTorrent installed locally but with the benefit of not needing your computer on after the torrent is loaded and files downloading directly to your attached drive so they can be accessed by any computer on your network.
On underpowered routers I also assume this uses less resources as the program runs locally on your computer to display only the status what is going on.
I am little lost on all of this installing etc..
Does the remote give the optoin to do rss torrents
I can't seem to find instructions on "screenshots" on how this is done
hi
When I executed on a netgeara R8000 v24 the command /opt/bin/ipkg-opt install transmission
a message error "Permision denied"
How i can to solve ??
Thanks in advance
Christian
hi
Thanks in advance
Christian
