Why Do You Need A Special Serial (USB-TTL) Cable to Debrick Your Router?
I have been asked a few times if there is a way to convert a basic USB cable to allow it to connect to your WGR614L/WNR3500L.
The answer is basically no - allow me to explain.
First of all I recommend the USB-to-Serial Cable: 3.3V TTL cables that are available here. They come with different types of connectors Bare Wire, 6 Pin SIP and Audio Plug Connector.
But the business end, the USB side is very different than a standard USB cable.
The key to these cables are that each one contains a small internal electronic circuit board, utilizing the FT232R chip, which is encapsulated into the USB connector end of the cable. They use FTDIÂ’s FT232RQ USB to Serial UART interface IC device which handles all the USB signalling and protocols.
These cables require USB drivers to make them work, but they are available free from http://www.ftdichip.com, which is then used to make the FT232R chip in the cable appear as a virtual COM port (VCP) on your computer. This allows you to communicate with the USB interface via a standard PC serial emulation port (for example TTY or PUTTY).
You could buy a Mini-USB to Serial UART (TTL) Breakout Board, 3.3V and plug a standard USB cable into it and then solder wires from there but for a $5.00 savings it's probably not worth it.
They also make other boards or you can just buy the chip by itself; at the end of the day, I just don't think it is worth the effort compared to buying the cable itself.
If you like hacking like I do and may brick your router a few times while playing with it get the right cable and make it easy to debrick as shown here for the WGR614L and here for the WNR3500L.
KeonW
Thank you very much for the
Thank you very much for the information I have shared. Did you know that cash for Clunkers didn't start and stop with cars, the program also applies to appliances. You can get a rebate, until the program runs out of money, of $50 to $250 depending on the appliance you buy. You can check out the government website for Energy Savers, and definitely all Energy Star rated appliances are on the list. Some won't even send you running for payday loans or credit cards, believe or not – and the rebate helps, too. It stimulates some spending, and that is good for the economy – and you get to save money on your power bill. That's win-win-win.
Henrik
Another option for connecting
Another option for connecting to the 3.3V TTL level, is to buy a cellphone-datacable. I've tried with the Nokia CA-42 cable, which in the no-name version I used is based on a prolific 2303 chip, enabling the usb to TTL communication. These are in the $4 range on ebay..
Best Regards Henrik
jassie liu
Dear Sir/Madam,
Dear Sir/Madam,
It's my pleasure to write you this mail.
We are a profesional manufacturer of HDMI cable, USB cable, etc.
I am writing to you just advise that we Micro controller buy FTDI USB to TTL 3.3V & 5V from our company, the price is $7.8 for 3.3v, and $7.9 for 5v.
You can check more details from our website http://www.tldcable.com for more details.
If there is any problem about our cables, pls don't hesitate to let me know.
Best Regards,
Jassie Liu, Overseas Sales Manager
TLD ELECTRONICS (HK) CO LTD
Shenzhen Tailide Science and Technology Co.,Ltd
Web.: www.tldcable.com www.tld.en.alibaba.com http://www.globalsources.com/tld.co
Tel.: +86-755-29821162 ext.816 | Fax: +86-755-29821164 | Mobile: +86-15016717185
Email: [email protected] | MSN: [email protected] | SKYPE: Jassie_Jizhuo
Add.: 5F, Hongyue Industrial Park,Yuanfen Industrial Zone, Longhua town,Baoan
district,Shenzhen,China
