WNR3500L with DD-WRT as Access Point
3 posts / 0 new
Christoph
Christoph's picture
Hello
My configuration: ADSL modem, Router (Netgear WGR614, only as Firewall and Router, WLAN is off), Gigaswitch. Now, I'd like to use my WNR3500L with DD-WRT as Access Point for my iPod touch etc.. This works, but I've the following problem: when I switch off the WNR3500L (power off) then my computer (connected per LAN at the switch) has no access to the Internet for abvout 2 minutes. Then it works fine again. I assume my WGR614 get in trouble and "reboot".
What can I do? Is my configuration wrong? Do I set RIP?
Thanks a lot
Christoph
Hogeye
Hogeye's picture
Use the LAN port not WAN to
Use the LAN port not WAN to connect from WNR3500L to Gigaswitch.
Disable WAN or select to use WAN as LAN in DDWRT.
Disable DHCP on WNR3500L.
Set DDWRT as router/access point not gateway.
Set default gateway in DDWRT to WGR614 LAN IP address (default-192.168.1.1).
http://www.dd-wrt.com/wiki/index.php/Wireless_Access_Point
I use Tomato but same applies.
Christoph
Christoph's picture
Hello Hogeye
Hello Hogeye
Thanks a lot for your good hint. Meanwhile I found the problem: my ADSL modem did more than I assumed. It also has an DHCP server, which I switched off now and it als has an option called "any IP", which I also switched off. Now everything works fine.
Thanks a lot again
Christoph
