Tomato and Optware
2 posts / 0 new
t2noob
Tomato and Optware
Hi I just jumped ship from Kong Mod (ddwrt) To tomato and i have to say its very stable and seems to be working better than any previous build i have tried. But I want to run Optware on it and it seems the procedure is different for tomato and I was wondering if anyone is running optware on their wnr3500l and how they did it?
I want to be able to run transmission and samba even though dlna seems to be running pretty well.
The hard drive i want to run it off has a 465 ntfs partition and a 1gb ext3 partition.
I found a site that has a script but it looks like it formats the drive and partitions it which is something i don't want because i have the hard drive about 350gb full and that would take forever to back up and restore. Any help would be greatly appreciated.
Striatum
I've configured without
I've configured without reformatting. Better to use ext3 partition.
Create an Optware folder on your partition.
In USB and NAS > USB support, insert this script in the 'Run after Mounting' box (Automount is selected):
# Mount Opt to Flash Drive of Choice
if [ -d /mnt/sda1 ]; then     <== Adapt here if necessary
(sh /tmp/scripts/flashLED.sh aoss 5000 6 off) & echo Flashing LED
 mount -o noatime -t ext3 -obind /mnt/sda1/Optware /opt      <= Adapt here
fi
# Flash LED
(sh /tmp/scripts/flashLED.sh aoss 125000 5 off) & echo Flashing LED
In the 'Run Before unmounting':
sleep 2
# Flash LED
(sh /tmp/scripts/flashLED.sh aoss 350000 3 off) & echo Flashing LED
Save.
The only thing I made was creating a swap partition on my harddrive, with a permanent entry in /etc/fstab:
/dev/sda2 none swap sw 0 0
(without forgetting nvram setfile2nvram /etc/fstab and nvram commit to modify fstab in nvram)
After rebooting your should have an a correct /opt folder (verify with df command via telnet or ssh).
Then via Telnet or ssh:
wget http://tomatousb.org/local--files/tut:optware-installation/optware-insta... -O - | tr -d '\r' > /tmp/optware-install.sh
chmod +x /tmp/optware-install.shsh
sleep 5
ipkg update
sleep 5
And it's done.
I've followed:
http://tomatousb.org/tut:optware-installation
You have some hints here:
http://tomatousb.org/tut:how-to-set-up-nas-optware-etc-for-total-noobs
But they don't use the 'Folder Method' for /opt.
