Hello everybody,
I've had flashed my WGR614L Router by an own compiled Firmware.
So, I don't know whats happend, so this Router isn't booting, some other Firmware. Firmware which worked fine before.
With an USB-Serial Cable, I see this:
WGR614v8 - 1.8 (Mon Apr 13 10:53:43 CST 2009)
Device eth0: hwaddr 00-0E-00-00-06-00, ipaddr 192.168.1.1, mask 255.255.255.0
Invalid image_len/image_chksum!
Decompressing..........done
CFE> ^C
CFE>
When I flashed, with an "good old" Firmware, happend this:
CFE> tftpd
Reading :: Done. 3145786 bytes read
Reading ::
So, I don't find any other people with the same bug.
Here are some Info's about the Router (NVRAM):
CFE> nvram show
opo=8
os_ram_addr=80001000
boardrev=0X10
il0macaddr=00:90:4C:C1:00:01
et0macaddr=00:0e:00:00:06:00
watchdog=3000
boot_wait=off
et0mdcport=0
reset_gpio=7
pmon_ver=CFE 4.131.30.0
vlan0ports=1 2 3 4 5*
os_flash_addr=bfc40000
sromrev=3
boardtype=0x48E
et1macaddr=00:00:76:ae:f4:cf
lan_netmask=255.255.255.0
wl0id=0x4318
ag0=2
wl0gpio0=11
xtalfreq=25000
wl0gpio1=11
wl0gpio2=11
wl0gpio3=11
boardflags2=0
cfe_version=1.8
wait_time=3
pa0itssit=62
pa0maxpwr=82
lan_ipaddr=192.168.1.1
clkfreq=240
aa0=3
vlan1hwname=et0
sdram_config=0x0032
vlan1ports=0 5u
scratch=a0180000
ccode=0
boardflags=0x750
wandevs=et0
sdram_refresh=0x0
sdram_ncdl=0x20326
et0phyaddr=30
noset_try_flag=1
landevs=vlan0 wl0
pa0b0=0x164B
pa0b1=0xFA66
pa0b2=0xFE86
sdram_init=0x000A
vlan0hwname=et0
dl_ram_addr=a0001000
boardnum=0x01
command status=0
So, did anybody know, what's happend? Please help me.
Thanks alot,
THC
When you say "flashed, with an "good old" Firmware" do you mean the factory firmware? If not try it.
Yes, I've tried the factory firmware:
thc@laptop:~/Desktop$ tftp 192.168.1.1
tftp> bin
tftp> ver
Verbose mode on.
tftp> put WGR614v8-V1.1.24_14.0.43NA.chk
putting WGR614v8-V1.1.24_14.0.43NA.chk to 192.168.1.1:WGR614v8-V1.1.24_14.0.43NA.chk [octet]
Sent 3526714 bytes in 4.9 seconds [5757900 bits/sec]
tftp>
or some DD-WRT Firmware, which worked fine before.
All tries takes the same result at the router:
CFE> tftpd
Reading :: Done. 3526714 bytes read
Reading ::
I'll hope you can help me, please.
thc
So, today I've tested and analysed, but I can't find an(y) error(s).
But, if I had typed "nvram show" twise, so the router printed other results.
Here for example (uncutted copy and paste):
nvram show9on=1.8
wait_time=3
pa0itssit=62
pa0maxpwr=82
clkfreq=240
aa0=3
vlan1hwname=et0
sdram_config=0x0032
vlan1ports=0 5u
scratch=a0180000
ccode=0
boardflags=0x750
wandevs=et0
sdram_refresh=0x0
sdram_ncdl=0x20526
et0phyaddr=30
landevs=vlan0 wl0
pa0b0=0x164B
pa0b1=0xFA66
pa0b2=0xFE86
sdram_init=0x000A
vlan0hwname=et0
boardnum=01
command status=0
CFE> nvram show
opo=8
evs=et0
sdram_refresh=0x0
sdram_ncdl=0x20526
et0phyaddr=30
landevs=vlan0 wl0
pa0b0=0x164B
pa0b1=0xFA66
pa0b2=0xFE86
sdram_init=0x000A
vlan0hwname=et0
boardnum=01
command status=0
CFE> nvram show
opo=8
boardrev=0x11
watchdog=3000
boot_wait=off
et0mdcport=0
reset_gpio=7
sromrev=3
boardtype=0x048e
wl0id=0x4318
ag0=2
wl0gpio0=11
xtalfreq=25000
wl0gpio1=11
wl0gpio2=11
wl0gpio3=11
boardflags2=0
cfe_version=1.8
wait_time=3
pa0itssit=62
pa0maxpwr=82
clkfreq=240
aa0=3
vlan1hwname=et0
sdram_config=0x0032
vlan1ports=0 5u
scratch=a0180000
ccode=0
boardflags=0x750
wandevs=et0
sdram_refresh=0x0
sdram_ncdl=0x20526
et0phyaddr=30
landevs=vlan0 wl0
pa0b0=0x164B
pa0b1=0xFA66
pa0b2=0xFE86
sdram_init=0x000A
vlan0hwname=et0
boardnum=01
command status=0
CFE>
What's matter with this device? I've never seen before this.
Did any body knows, whats up with this WGR614L Router?
Hello m0j9,
jepp, I've flashed Backfire before, too. (DD-WRT and Kamikaze worked very fine before!)
So, I meant no harm by it, but it seems the root of all evil. :-)
It's good to know, I'm not alone ;-)
i love those
Mad Men DVD 1-4
Gossip Girl DVD 1-3
