Toastman Original Class Names Firmware?
5 posts / 0 new
abruton
Hi
I'm looking for this version firmware:
Tomato Firmware v1.28.7440 MIPSR2-Toastman-OriginalClassNames K26 USB Ext
Does anyone know where I can get it. I used it for one installation and it works well. Now I want to do another router and I cant find the firmware.
Andre
Brandon C
abruton said: Hi I'm looking
abruton said: Hi I'm looking for this version firmware: Tomato Firmware v1.28.7440 MIPSR2-Toastman-OriginalClassNames K26 USB Ext Does anyone know where I can get it. I used it for one installation and it works well. Now I want to do another router and I cant find the firmware.
Here is the latest list (7445) from his FTP site. I am running 7445 now and t's working fine.
abruton
Thank you!
Thank you!
I need the original class names. I wish there was a feature to add and delete class names.
Andre
Toastman
I just posted some
I just posted some information on these builds:
http://www.myopenrouter.com/forum/thread/24906/Does-Anyone-use-Toastman-...
Here's a link for the revised download site:
http://www.4shared.com/dir/v1BuINP3/Toastman_Builds.html
Toastman
BTW - I added the facility to
BTW - I added the facility to change the class names. Try to get 7467.
