does anyone know where i can get old kong builds? i need something around k26-r14929 or 15704, but it seems that the links on this board keep getting updated to the latest build.
(i need the old builds because i have an older router with corerev<16)
thanks in advance.
Hi there--I do have a link to eko's repository--maybe that will help you get up and running in the short term:
ftp://ftp.dd-wrt.com/others/eko/V24-K26/
Not sure where the older Kong builds can be found--hopefully he'll see this thread and help us out!
Usually I delete older versions once I know that the latest builds are known to be stable but I have a few builds left: DLNA or VPN r15000
thank you, kong.
the problem is that
"[b]UPDATE It is now learned that any router with a corerev lower than 16 will no longer be supported with the K26 builds after ~16500. (per Eko) " (from dd-wrt board)
see this router- corerev list:
http://www.dd-wrt.com/wiki/index.php/Corerev_List
any chance you also have r15704/r15758?
