Good morning.
I have WNR3500l and DD-WRT Kong Mod USB/FTP/miniDLNA/Samba3 Build 17140.
I'm having trouble finding the router on the LAN by name. It just is not there. Samba is working on the ip address, DLNA is visible.
Maybe some tips?
Thank you for your help.
Can not find the router by name- Kong Mod USB/FTP/miniDLNA/Samba3 Build 17140
Wed, 06/08/2011 - 12:27am
#1
Hi gawar,
I have just uploaded updated bins yesterday, which fix this problems, see:
http://www.myopenrouter.com/forum/thread/28422/Kong-Mod-build-17140-Upda...
Check your md5sum to see if you have the latest build.
Yes. This software has removed the problem:). Thank you!
