Cross compile, or build enviromnet
4 posts / 0 new
flashed
flashed's picture
Could anyone tell how to cross compile custom software for Tomato ?
I have installed optware and it works fine, but now I would like to compile my own software.
thanks!
Subhra
Subhra's picture
You will get the steps to
You will get the steps to build tomato from the link below....
http://tomatousb.org/tut:how-to-rebuild-tomato-software
Btw,for which hardware are you trying to compile it?
flashed
flashed's picture
Thanks. I got it working. The
Thanks. I got it working. The CPU is mips.
The router is (if I remember correctly) Netgear WNR3500L.
Subhra
Subhra's picture
Good to know that things are
Good to know that things are working at your end. Netgear WNR3500L uses mips (liitle endian) cpu.
