Hi Kong,
I tried both your latest builds 17356 on my Belkin 8301 but other than my wired clients none are getting ip through dhcp. i tried all combinations also tried manual(Additional DNSMasq Options) config but no luck i tried both 192.168.1.0/24 and 192.168.0.0/24 but no go. other than that everything else is just greate. hope i get some help fixing this.
TiA
iCE
If your wired clients get an ip then the config is probably correct, to findout why dhcp over wireless fails is to run tcpdump on the router to trace the communication. Tracing the client side with wireshark could also reveal the cause.
so i rechecked my config when i use dhcpd all my clients get ips when i use dnsmasq for dhcp none of my clients get ip.
