- After the initial Kong Mod 4 weeks 1 day ago
- Working the EXACT same 4 weeks 1 day ago
- While the "5 Easy Steps" 1 month 1 week ago
- R8000P would be grate to see. 1 month 1 week ago
- Have a R8000 but ordered a 1 month 1 week ago
Hi Kong,
at last Automount without always SSHing to the command line after reboot.
Thanks a lot!
eTaurus
Anybody else get swap working??
Mem: 124416k total, 26952k used, 97464k free, 1372k buffers
Swap: 127992k total, 0k used, 127992k free, 13608k cached
Here is running, I guess.
Kong, Can you check the broadcom wireless drivers on 15508M? With this 17462M I have very unstable signal on every single channel, after some hours of uptime. Namely, it locks on 39 mbps link speed and decays signal from -30 dB to -60 dB.
With 15508M none of this happens.
I've seen some problems with the latest wireless driver too. So I'll downgrade them again.
Kong, please downgrade it to the driver on 15508M Eko. At least compile two versions for testing proposes.
It may be possible the issues are on wireless driver, but we never know until testing.
From 15508M to 17462 are too many builds between and code modifications...
kt_haddock, where is it?
Discussion about this wifi issues on DD-WRT forum:
http://www.dd-wrt.com/phpBB2/viewtopic.php?p=634123#634123
Best regards,
@kt,
I've been testing with the latest drivers and I experienced some signal up and downs on saturday. The signal jumped between 10-40% and my client reported around 7mbps although I was sitting 5m away.
Usually I get 72-144mpbs. A reboot fixed it. With the previous driver I didn't reboot for weeks without a problem.
I have experienced lockups with wifi in this build. I wounder if it is related to my setup. I have two ssids one using wpa with aes and the other using WEP 128 bit. I am using WDS to the other router in my family room. I have downgraded to kong build 17356M on the main WDS router, a WNR3500L, and have dd-wrt buld 17461 on the client WDS router, a WNR834Bv2, and my connection seems stable. If I upgrade the WNR3500L to this build things seem fine at first then with in a few hours the wifi connection will lock up. It seems to lock up quickly when there is 2-3 MB/s of data being transferred over WDS, such as streaming a 720P video.
@Rich, I guess you missed that one:
http://www.myopenrouter.com/forum/thread/30861/Kong-Mod-Update-build-17586/
